Aus dem gixxer forum
Hi there,
so i searched the internet to find a tutorial about how to install a Domino Kill switch on my gsx-r750 k8.
My Domino switch has 4 wires, and the gixxer has a connector with 8 pins/wires and a connector with 2 pins/wires.
WHAT YOU HAVE TO KNOW:
-On the 8 pin connector, 2 wires B/R and B/Bl are for the front brake switch and have nothing to do with the wres we need to know about to change the start-On/Off switch.
- if you install a racing kill/switch you will loose the oem "map change buttons". You still can use other switches to choose oem mapping, or a switch if you have bazzaz or powercommander mappings.
- By installing a racing switch you won't need to follow oem wire colour of the oem harness like (+) or (-) because the start and on/off buttons are simple closing-switches and don't have any diodes that would require to respect a (+) and (-) pole.
-You won't need the 2 pin/wire connector for the mapping switch. I tested the map-switch to see if pushing the switches would open or close a circuit, but they are 'closing switches', so no influence by removing the 2 pin connector.
- You won't need the Yellow/White and Orange/Red wire going from the 8 pin connector to the oem Starter Button. Actually the Y/W and O/R wires are there, but don't assume any function in the electronic needs. (look at the picture).If you look on the other side of the 8pin connector you will notice that the Y/W and O/R wires are not connected to anything on the rest of the harness. Like on the picture.
NOW WE KNOW WE NEED ONLY 4 OF IN TOTAL 10 OEM WIRES (2+8pins).
When you connect the 2 wires of the starter and 2 wires for the on/off, the color of the wire doesn't matter. Just take care in connecting the both starter wires and the both on/off wires and don't intervert a on/off wire with a starter wire.
Starter button needs>> Yellow/Green and Orange/White
ON/OFF button needs>> Orange/White and Orange/Black
I think this method works for other gixxers and other years aswell.
Hope will be usefull for some.
- - - - - - - - - - - - - - - - - - - - - Neuer Text innerhalb von 30 Minuten - - - - - - - - - - - - - - - - - - - - -
Und noch die Fotos
